Page 163 of 375 FirstFirst ... 63113153161162163164165173213263 ... LastLast
Results 1,621 to 1,630 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #1621
    I'm Jez.
    Just stumbled across this... would have guessed trade area or strokes of genius.... no matter.. Barry had to ask about the sockets as well Is it not obvious that the ones next to the ground "binding post" are the input ones? Maybe not....
  2. #1622
    Well that was my thoughts and was right. I have finished mycappraisal and have asked andrew for the forwarding address.
    I'm Jez.
    Bloody 'ell that was quick So come on then what's the verdict? Be gentle with me
  4. #1624
    Packaging could have been a lot betterat bottom... Folk forget the bottom.... Anyways its as Martin says...fucked! Its in shed till i calm down in a year or 2. Then i will dis assemble it and see what can be done....if i live that long... Parcelforce 24... Useless bassas.
    There claims dept will say Insufficient packing. No claim after a quick look at pics...so wont even bother.
    Quote Originally Posted by Arkless Electronics View Post
    Its very good Jez. Nice clear sound. Good soundstage. Good output are plusses... On down side well not too much... Its a tad lean with bass on my system and it was difficult to find a place where some rf was not being picked up.. Better shielding would fix that though i guess. My mm stages may not have suited the cart as well on this system.
    It was the best ive heard the mm on the amp sound but my main mc stage for me beats it.. Sure others will disagree though.
    Conclusion is if i was a looking for a head amp to turn a mm into a mc and didnt have a good mc i would definately give this serious consideration...well done and maybe the dearer head amp your making will address the hum issue if not the leaness which im happy to accept may be my system or me
    I'm Jez.
    2000 series eh.... The tuner was the star of the pair 'n all.... amps not much cop. Both hi tech for the time...
  7. #1627
    Ah well i may never know now!
    I'm Jez.
    Glad you liked it I did have issues myself with RF pick up but only from my wifi modem when it was 2' from the head amp ("woodpecker" type interference). As you say the more expensive metal cased version will cure this and it's likely not an issue for most.... unless they also have a wifi modem right next to it!
    As far as bass leanness goes well it's -3dB @ 0.7Hz
    As an aside I reckon that the ubiquity of wifi has become a real issue as regards RF interference since it's universal adoption....
  9. #1629
    Shame the Leak tuner got busted by some dimwit who likely wouldn't give a toss. I've received a couple of damaged items in the last year. Each time, I've contacted the seller and sent photos and suggested a part refund or they can have it back and you want all your postage back too. Both times I got a substantial part refund as requested. It's worth a try, they certainly won't want it back after seeing pictures and being asked to repay two lots of postage.
  10. #1630
    I'm Jez.
    I had an amp and PSU in for some work a month or so ago and the sender merely put the PSU on top of the amp and put them in a cardboard box and sent them... no other packing It arrived with the box wet and falling apart with only the packing tape holding it all together! How it survived with only a small scratch god only knows. It went back properly packed.
