Looking good Grant. How are you finding the treble response?
Seems very decent being driven by the wad. The wizzer cones do a good job. My hearing doesnt go super high these days but you can usualy feel it ifits not there even if you dont hear it.
They are a tad big a!d powerful for my needs tbh so they wont get much use i fear. May sell them and recoup my outlay later on. Not that many folk these days rate fullrange speakers which is a shame as well done they have a lot going for them. Wouldnt be a problem if more was needed as a supertweeter could always be added..
Ive got my first loves back in now...the Telefunkens listening to of all things the OST of Paint your Wagon....marvelous stuff
Got the itch quicker than expected and dug out one of the Rogers cabs.
Decent strength in these although not the easiest to work on I think.
Cut out the old tweeter to accommodate a five inch wizzer driver. The eight inch driver fits in the main hole.
Tidied the shed a bit toi
Hope you're going to enclose the back of the smaller unit and roll it in with a biggish cap.
This is the out section of the integrated version of the amp Alan. Cant find the power version but other than the selector and vc I think they are identical
spec
Power Output............................................ 15w/c
Operation......................................... .........Ultralinear
Tubes............................................. ..........4 x EL84
.................................................. .....2 x ECF80
Input Sensitivity....................................... ..380mV
Input Impedence ........................................100KOhm
Frequency Response.................................17Hz to 30kHz (-1dB)
Distortion........................................ ..........0.02% at 1kHz, 1W output
OK Grant, I'd forgotten that the WAD used the feedback resistor R32/33 to generate the bias for the input pentode.
It's still very easy though, increase the value of the 22R resistor R8/9 to 47R or even 68R.
The input sensitivity will then be 855mV for 47R, or 1.14V for 68R.
Thanks again Alan for your time and trouble. I will have a look see what i can do when a bit better ..... Sounds pretty simple and if i dont have those values i will get some in.
