Page 130 of 375 FirstFirst ... 3080120128129130131132140180230 ... LastLast
Results 1,291 to 1,300 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #1291
    You'll get there Grant. I know you have the patience. I'm looking forward to your observations on these.
  2. #1292
    I always have the fear that after all the work when i fit the drivers they sound CRAP! ..... not happened yet but it is always at the back of your mind Geoff.
    The cab if weather and my health hold out will probably take a week. Then Its just fit the drivers and hold on to your breeks
    I'm Gary.
    Ach...
    Theres always the next set of cabs to work on...
    These ones however look a wee bit spech Grant!
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  4. #1294
    I'm Peter.
    I'd be too impatient and fit the drivers first and test them. If they were good, I'd probably never get round to the cosmetic stuff
    Love the work you do, Grant. When you replace drivers, do you 'tune' them by ear, or have you any measuring kit you use?
  5. #1295
    Normally its a bit of guesswork Pete looking at similar jobs in similar sized cabs..not very scientific lol.. This one i have done a little checking and math through a site and as the cabs have a limited depth i can probably only get to 8 inch length max and hoping 7 will do. So ears will be used. Ive marked the tubes in inches to guage the effect. As ive said im no pro, just like playing
    A little rubbing down top n bottom. A big gouge and a few lesser ones becoming less
    And with a touch of magic in 40 secs
    A trick I use to bring gouges up and out is to put hot damp cotton wool along them for a while. The moisture swells the compressed wood fibres and raises the surface. Often the mark will then sand right out.
  8. #1298
    Water can be useful, yes. Its good to raise the wood hairs for a final sand or sometimes to stain. Decided to try disguise this time with my graining pens and then sand very lightly till it blends.
    I'm Shane.
    Have you ever met Geoff, Grant? His head is MASSIVE making his body look tiny.
    Man Geoff, you should sell some knowledge in different prices
    S.
  10. #1300
    Hi Shane. How're yer doin' mate?
