Page 102 of 375 FirstFirst ... 25292100101102103104112152202 ... LastLast
Results 1,011 to 1,020 of 3741
Thread: I Think I'm sure I'm Finished...or Zeppelin to Sinatra & Back
  1. #1011
    Thanks Martin..and yes i think your right re wall being closer and it will be. have it back out in wshop for further fettling but am on to cab 2....took me 3/4hr just to get the driver and what he thought were speaker pillars 2 long star bent screws and 2 threaded bend bolts with overtightened nuts..thread damaged! at least it wadnt gonna fall out. pics later. time to do shopping
    some pics of the 2nd case...in some ways its worse.
    etc,etc..
    some repairs at first stage
    and the driver with its dodgy wiring
    banana posts fitted to speaker1
    With everything going on I forgot to show my new toys. Have been discussing supertweeters with geoff and I decided yesterday to order good ones and make a set. But the day before I had ordered a made up set (cheap ones tbh) judt to try in meantime. It was lucky I did as the full ranges liked them reinforcing my need for a set. They added a bit of bass for some reason as well as top end. They are switchable small and quite neat. Work real nice with the kefs.
    The bigger ones i ordered last night were mentioned here yesterday but wont be here for a while. Ribbons. 100mm 8ohm
    as for my claims the main system was forever fettled my wad decided to play up so the proart mono are back in as are the kefs with new stweets. have to say it all sounds very good with this tvc pre
    Have you got a link for the cheap stweets Grant?
  6. #1016
    http://www.ebay.co.uk/itm/3218041248...STRK:MEBIDX:IT
    it was there only set but sure theyll make more. not bad for money tbh.
    alan whats the most likely thing to be causing a little roughness in the wad kel84 on 1 channel.. caps or resistors?
    got a little more done on cab 2. its solid but badly chipped and scratched. level of abuse is remarkable and says somethinvvabout the original strength of them as a modern cab would have disintegrated.
    shouldnt need an awful lot more tbh and the flash makes them look worse than they currently are as the repairs refract light differently
    Unfortunately it's difficult to guess from a verbal description.
    Best thing is to get a scope on it, particularly as one channel is good, the two channels can be compared.
    Without a scope the respective voltage levels on each channel could be compared from the good channel to the rough, this might give a clue.
    You need a techie to give it the once over. I don't think my fluence stretches past Manchester
  9. #1019
    once i get the speaks finished i will have look.
    ta for response....
    These cabs according to my calculations are 48 litres so probably a bit short of the ideal. would have preferred 75, but will have to wait for something to appear on the bay or on here at the right price. I dont have the tools now to start from scratch. still make do and mend was my ma 'n' da's motto
