Looking good Chris.
Just make sure you use a good quality switch with low contact resistance and no neon power on light.
You don't want to add additional noise to your incoming supply.
Missile switch
Looking good Chris.
Missile switch
So made some progress recently. I'd appreciate some opinion of the measured voltages incase any are adrift of normal.
Output from the stock Transformer - 33.6vac
Output from Ken's PSU - 43.7vdc
Output from Ken's Regulator - 20.2vdc
Do these sound acceptable?
Alas the missile switch cover is a no-go as it's sprung loaded mechanism just turns the switch back off!
Thanks as ever.
Chris
Looks good!
SP-10Mk2a, Graham 2.2 tonearm. SL-1200, Graham 2.2 tonearm, AT-150mlx, Benz-Scheu Glider. Jim & Ken Super DC PSU, Oil well bearing, Acromat, Isonoes, strobe lamp switched. Pass Labs Pearl 2. Aleph J amplifier. F6 Amplifier. Nelson Pass Burning Amplifier BA-3. Pass BA-PP linestage, miniDSP 4x10, Linkwitz Labs LXmini speakers, Sony SS-M7 speakers.
DIY In progress - Syclotron Red Light district valve amp, ZenMod "Iron pre" autoformer jfet preamp, SYclotron 'His Master's Noise' valve phonostage. And about 2-3 other projects in various states at any time.
Many thanks all!
Chris.
