Kevin
Darren - Bear in mind electronics is not my field but..........
Do not use the combined secondaries of 50v it is too high a voltage.
Using the formula that Neal has given to show the increase in voltage that the rectifier process produces you will end up with 70.7v less some losses. This is too high for the LM317 which while having no real limit on input voltage does have a limit on the differential between input and output, which is an absolute maximum of 40v difference according to the spec.
We are outputting 20.6v so anywhere near 70v input has to high a differential (approx 50v).
I think what Neal is saying is that just one of the 25v secondaries is enough to do the job as it will produce a rectified 35.35v less some losses along the way. This will be ok for the regulator to further reduce to 20.6v as the differential is now down to approx 14v.
The stock Techie Tranny does produce more than required as was said further back. The result of using a smaller input voltage at the regulator will be less heat produced by the reduction process.
You could certainly try using a single 25v secondary without harming anything and see what the regulator produces before connecting its outputs to the board.
I have simplified things and not taken load etc into consideration but I think it should work.
But do not connect the secondaries and use 50v.
If someone more knowledgeable sees a flaw in what I am suggesting please jump in.
Thanks for the input guys and thank you Ken for putting this in a language I can understand! With this in mind is there are advantage in using one of the toroidal secondary's at 25V? Is ~32V from the stock tranny better than ~25V from the toroidal? Does higher voltage provide more overhead / redundancy or will the lower voltage allow the rectifier and regulator to run more efficiently?
I will hook 1 x 25V secondary to the PCB (disconnected from the motor board), take some readings and report back.
Thanks everyone.
Darren.
Listening Room.UNDER CONSTRUCTIONTurn Table. Garrard 401, Reso Mat, 2 Tier Slate Plinth, DIY Hadcock GH242, Nick G modded Lentek, Denon DL-103.
Pre Amp. Croft Super Micro2. Power Amps Quad 405 Mono Blocks.
Speakers. TBC
Home Cinema.UNDER CONSTRUCTIONDAC/Pre Amp. Denon AVC X3700H.BDP/Streamer. Panasonic DP-UB820EB / Apple TV4K.Display. Optoma UHD51 / DIY False Black Window Screen.
Power Amps. 2 x Nakamichi AVP1.
Front Speakers. DIY Baby Celestion Ditton 66. Surround Speakers. Celestion Ditton 11. Subwoofer. BK Electronics P12 300SB PR.
Old Gallery. http://theartofsound.net/forum/showt...-of-the-70%92s
Ken, you are spot on in your caluulations.
The LM317 has much less 'dropout' -- the voltage lost to the regulator itself, the minimum input voltage required to get a certain output, than the stock discrete regulator. Usually the LM317 needs just a couple volts (2-3) more on the input than the output you ask of it. SO, as we only need 20.5-21.0V on the output, if the input is as low as 24V it will be just fine. Some similar regulators have only 1V of dropout. Cool.
Darren, if your unregulated PSU voltage is in the 24-35V range, you will be fine.
Now, as to the transformer, don't hook up only one secondary, but parallel them. Red+Yellow together, that's your AC1, then Black+Orange, that will be AC2
Higher voltage is less efficient, as the regulator needs to burn the excess voltage into heat. (That's it's job) So more is not better in this case.Originally Posted by Darren
If you connect them in series, I.E., Red AC1, Black + Yellow, Orange AC2. That would give 50VOriginally Posted by Ken
SP-10Mk2a, Graham 2.2 tonearm. SL-1200, Graham 2.2 tonearm, AT-150mlx, Benz-Scheu Glider. Jim & Ken Super DC PSU, Oil well bearing, Acromat, Isonoes, strobe lamp switched. Pass Labs Pearl 2. Aleph J amplifier. F6 Amplifier. Nelson Pass Burning Amplifier BA-3. Pass BA-PP linestage, miniDSP 4x10, Linkwitz Labs LXmini speakers, Sony SS-M7 speakers.
DIY In progress - Syclotron Red Light district valve amp, ZenMod "Iron pre" autoformer jfet preamp, SYclotron 'His Master's Noise' valve phonostage. And about 2-3 other projects in various states at any time.
I'm ChrisB.
The AoS warning about working on the mains is wisely posted at the beginning of this thread. However, I think it is worth posting a reminder here.....I promise you that even the very best upgrade will be a total waste of time if you have to listen to it from the inside of a coffin at the bottom of a 6 foot deep hole in the local cemetery.
STOP!
Before you put yourself or others in danger, think very carefully about whether you are qualified to carry out any of this work.
Art of Sound Electrical Safety Advice
The Art of Sound is an open forum for music lovers and a place where all members can share their views on music and the equipment used for its reproduction.
The forum also caters for those who are interested in the DIY aspect of everything related to the audio replay chain, and therefore there will always be a healthy number of DIY articles and discussions in threads across the forum. Given the number of these, it is not possible to monitor or moderate all technical aspects of posts made by members.
The Art of Sound would therefore like to remind all who read such articles that while we encourage discussions on all audio related DIY we cannot and will not accept liability for the information given on any DIY related matters contained in any thread or posts herein.
We strongly advise extreme caution when considering any modification or building projects described, especially those concerning any mains voltage related upgrades, earth modifications and/or any other high voltage related modifications or building projects.
Unless you are suitably qualified or otherwise capable of carrying out such modifications/suggestions, then we strongly advise you consult qualified personnel.
We would also like to remind all our members and readers that some or all of the modifications found within the threads and posts of the forum may not be legal in certain countries and therefore advice on the legalities or otherwise should be sought before carrying out such modifications.
You'll get about 32v out of the 25v secondary with full wave rec and smoothing cap. So will drop about 11v across the reg. I think power draw is what 120mA for the 1210? Call it 150mA @ 11v or 2w as near as...heat sink it well.
Safety warning received and understood, I take full responsibility for my actions and all reasonable precautions to avoid a Darwin nomination.
Darren.
Speakers. TBC
Darren.
Speakers. TBC
Mystery of fluctuating voltage solved! A case of user error with the multimeter, I had it set to dc not ac
With the multimeter set to ac the tranny reads a constant 31.5V in parallel. Thanks for the input and sorry to have wasted everyone's time.
Now just got to fit it into the new enclosure, boy do I feel like a cock
Darren.
Speakers. TBC
