Well no problem, this is just a matter of personal taste and feelings.
Anybody can be satisfied with whatever product he feels like.
I just give my opinion in case someone is interested :-)
As far as my dealer is concerned, our conclusion came only from what BOTH of us heard ...
I just don't subscribe to the way some people rate different dacs, but I have no problem with that ...
What I can say so far is
- I got excellent results with the squeezebox on a decent system, and I really consider the squeezebox is an excellent value for money (as a dac, and it gives much more than a dac).
- I got slightly better result with the TC-7520 on the same kind of system.
- I got much better results with CD players and other dacs on the same kind of system (and I have several others to try).
Up to now, on my system, compared to all sources I tried, including Squeezebox and TC-7520 LM4562NA, my dead old CD player was much much better, without the slightest hesitation.
I think it is useless to search in the Dac Magic price range.
Now, people can perfectly think that when a TC-7520 doesn't spank a squeezebox, or doesn't sound almost as good as higher end dac, this is due to the power supply, the op amps, the amplifier, the speaker, the cables, the transport or whatever else you can think of ... which prevent the TC-7520 to show its qualities ...
Note that you could also think that when someone says that the squeezebox is just "Great to play though a high street electrical shop mini-stack", or when the high end dac is only marginally better than the Beresford, it could simply be because you didn't spent weeks finding the right setup for the squeezebox or the high end dac ...
Every serious dealer I spoke with, think that Dac Magic is not in the 1000 euros dacs league, and is a good "multimedia" dac.
I agree.
I don't find the TC-7520 vastly superior to the dac magic, may be sometime different, but not really "better".
I cannot consider a dac "spanks" another one, if it takes me some time to notice I accidently left my amplifier on the SB3 input instead of the Beresford input, on my system, with my cables.
You asked about my digital cables.
At home all cables I use are bluejeanscable, at least 1.5 meter length for digital.
Shorter digital cables are apparently known to be the source of reflection problems.
Up to 5 meter, with decent cables, there should be no length problem.
And most high end digital cables comparison I heard of, used shorter lengths, one meter or less ... so are they relevant ?
When I wrote I found no difference between optical and coax, I was only talking about the TC-7520 with bluejeanscable optical and coax connected to the squeezebox.
If you need to spend several times as much as the dac in power supply, op amps, digital cables and so on, to see its qualities, as far as I am concerned, I'm pretty sure I'll spend more in the dac and keep my bluejeanscable ...
I think the digital treatment to the data sent to the dac is much more important.
For example, you wrote somewhere that the Playstation 3 was a bad transport for you.
Are you sure you configured it with the correct settings ?
If you let the playstation convert everything to 48 Khz (I think it is the default setting), no need to say that comparison with another transport is useless ...
I'm interested in your results since your system seems really good, and should show differences in dacs qualities.
The squeezebox classic is quite cheap.
I think you should really try it.
It is an easy way to suppress most problems you can have with softwares or drivers which can silently resample or transform the digital signal.
