Quite right Dan.
Bob - we can surmise from your first post that you'd prefer the Quad. If you want to vent about how inadequate valve amps are, then the place for that would be on another thread.
Back to the matter in hand.
I'm ChrisB.
Quite right Dan.
I'm Gone.
I do t take offence even if someone thinks I'm crazy or just plain stupid for my choices. After all, it's only me who has to listen to my bits and the same with anyone else
What I will say though is that the best amps I've had, whether valve or solid state, seem to have more similarities than differences. My Puresound and My NVAs for instance, differ very little in terms of tonal balance and presentation. I don't hear massive distortion from the valve amp, so. I don't worry if measuring equipment can pick it up.
I have left AOS.
I'm Bob.
It wasn’t my intention to start a slagging match. I was giving my honest opinion as to which I believe was the better choice. I merely tried to qualify my choice. Anyone can say that A is better than B or that Z is better than Q but isn’t it better to say why? I don’t get all defensive if someone doesn’t like transistor amplifiers and I don’t think they are being rude for saying so, just less informed.
I'm Richard.
Bob - I've started a thread
Regards Neil
I'm Bob.
To try and bring this thread back on track, I ought to point out that the Quad 405, 520, 606, 707 and 909 power amp designs all use the "current dumping" circuit topology. Some have described this as having a 'grey sound', though I believe that criticism really only applied to the 405-1.
The 606 was a development of the 510/520 design, themselves a development of the 405. Both the 606 and 909 reperesent excellent value for money, though if you choose to buy one of the latter, make sure it was built in Huntingdon. Since Quad was sold to the Chang brothers and manufacture moved to China, word has got out that the later versions built there have used inferior, locally-sourced components in their construction (capacitors in particular), to the detriment of sound quality. Beware!
Again The Audio Innovations 500 is an excellent 25w/channel valve amp. I have had extensive exposure to this amp and regard it as one of the better valve designs. Sadly the company is no longer in business, so should you buy one and it needs service you will have to look elsewhere.
I'm going to avoid commenting on the pros and cons of the EL34 valve (I'm not really qualified to do so), save to say I regard the AI 500 as a 'modern day' Radford STA25 III, with a built in preamp.
Barry nice answer
