That's great Stan thanks.The BM11 sounds superb in my system but it's good to know that there may be a bit more to extract from it.
Jerry
Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
I'm yigit.
I use romoss eUsb edge 52 with my caimanII without any problem.
I'm tony.
I still have my BM2 and regard it as a keeper-it just marries up with HD650s perfectly. It has the battery optimised firmware but a further upgrade would be welcomed.
I have just bought the Anker® 2nd Gen Astro Pro 15000mAh off amazon to power my Caiman 2. it cuts out after about 10-30 seconds because the power pack switches off. I have read this issue with the Bushmaster but didn't realise it affected the Caiman. is there a cable i could buy to address this issue or will anyone make one up for me at cost. my skills are very limited.
I'm Adam.
You need a Y Cable like this :-
http://www.ebay.co.uk/itm/PLUGZ2GO-2...item339279e7f3
...and then a 12v grain of wheat bulb (I prefer the Clear colour) :-
http://www.ebay.co.uk/itm/Grain-of-W...item2580b8264c
...and a connector like this :-
http://www.ebay.co.uk/itm/Pair-of-12...3D181312916297
This will give you all you need to connect the bulb to one end of the Y cable and your Caiman to the other end of the cable (the special little green connector takes the wires from the bulb and you can insert the other end into the Y Cable).
Use the existing cable with your Anker battery to connect the battery to the female input of the Y Cable.
No soldering needed - fairly easy - even I managed it !
Adam.
I'm Jon.
FWIW, I recently bought two Anker Pro 20,000mAh batteries from Amazon (£40 each) to power my BM1 and neither has any cutout issues.
I'm denis.
hello to all of you first, and second i came after longtime because i want to said that the Stan update for the battery of the bushmaster mkII is so great change ( airier and 3 -d soundstage) that if you dont feel it immediately after installing it that say much about some feeble link in your gear... The most important modification about your gear will be installing sorbothane in all pieces of your gear... read about that, and trust me you will hear the Stan update so clearly and for sure the abyssal difference between the psu and the battery mod. ... thanks to all
I'm Derek.
Morning
the battery of choice from this thread
https://www.amazon.co.uk/20000mAh-Mu.../dp/B00GSLRKJO
is no longer available.
Anybody have any recommendations for something that works well that's current? (No pun intended!)
Thanks!
I'm Adam.
I am now using this power supply to power both my SEG 15V and Squeezebox / Raspberry Pi 5V :-
http://www.ebay.co.uk/itm/1113288910...%3AMEBIDX%3AIT
Adam.
I'm Derek.
