Stan, you might aswel remove the Ebay link.
I ordered from the offering seller but last night my order got cancelled because they had stock problems.
Now going for the other link you posted
I'm Martijn.
Martijn
I'm tony.
Maplin is selling a 12v solar charger for £10...have three put aside, will report back if it does the business for the ECO hi fi!!!
Thanks, Stan. That battery unit is very interesting. I think I might give it a punt.
It occurs to me that, rather than reintroduce a switched mode charger into my system, I can use my Paul Hynes 15V linear power supply to act as its charger. The best of both worlds.
Website: http://www.homehifi.co.uk
Website: http://www.beresford.me
Website: http://www.homehifi.asia
The unit specifies DC input voltage range of 14 - 24V. I thought all the sensing was in the main unit and that the charger was just a standard external SMPS power supply?
Now I'm confused
Those specs I quoted (DC input 14 - 24V) are for the battery unit you recommended in post #1. Clearly it has its own charge management circuit. I take it you have one of them?
as long as the supplied power charging source that came with the battery pack has no electronics in it, is a dumb PSU then it should work fine.
My "hi end" battery finally arrived from Ankaka after issues in Singapore customs. Battery/case is a sleek and solid bit of kit but there is a fault with the charging cable/plug as it will only charge in a certain position. Anyway, to my old ears this does raise the SQ another notch or 2 over the 6800mA/h battery I was using (which is already better than the linear psu/sBooster). Improvement is more in the area of sound stage and presentation (fuller/larger) than necessarily in detail. Definitely worth the wait.
Steve
Always a little further
Stan , can you please tell me if this would be suitable for the Bushmaster 2.
http://www.ebay.co.uk/itm/1611236012...84.m1423.l2649
