Thanks for that Michael.
According to the spec sheet supplied with my EMT TSD-15 (I have two of them: one fitted with a spherical tip, the other with a "fine line stylus") and EMT XSD-15 cartridges, the internal resistance is 22 Ohm and the output 0.15mV.sec/cm, so 0.75mV@5cm/sec.
To date I have run them either into the Quad44 fitted with "4A" phono boards, or a Mark Levinson ML-25 phonostage set to 100 Ohm and 44dB gain.
I'm not sure what the loading is on the EMT 155st equalisation amplifier fitted to my EMT390 turntable. I'll have to look at the circuit, but from memory I believe it is ~ 200 Ohm.
Nice to learn the JSD 6 is a good match with the SME V. I have a "nude" or stripped-down EMT 15 generator that needs repair. One day I will probably buy myself an SME V and fit the EMT into that.
Thanks again
