Results 1 to 10 of 19
Thread: AMB's γ1 Miniature DAC Project
    Default AMB's γ1 Miniature DAC Project
    I had been thinking about putting together a "portable" headphone system to use in the consevatory in readiness for those warm evenings (Har Har!). This system was (hopefully) going to sound as good as my main system - Squeezebox Classic > TC-7520 (modified) > DIY M3 Headphone Amp > AKG K701 Cans.
    Enter the γ1 (gamma 1 http://www.amb.org/audio/gamma1/ ) which I had read about a while back. It seemed to fit the bill - USB, Coax and Optical inputs, compact, USB or wallwart powered.
    A quick check on the parts list - Looking good, should cost less the 100GBP complete.
    So I went for it.
    Well, I have just completed the build and the unit is bedding in (is that necessary?).
    I was expecting reasonable performance, but this little DAC is seriously good IMHO - Well above my expectations, and then some!
    And what a nice little project - Perfect for any DIY electronics fan.
    If any of you guys are interested, I will take and post a few snaps of the DAC, and also my take on how the γ1 compares to the TC-7520.
    Cheers - Ken
    __________________________________
    "Subtle is the Lord, but malicious He is not"
    - Albert Einstein.
    leo's Avatar
    leo is offline Circuit Junkie & DIY Room Forum Leader
    Course we are interested Ken pics, opinions and comparisons are always welcome on here
    I'm john.
    Quote Originally Posted by sponge View Post
    I had been thinking about putting together a "portable" headphone system to use in the conservatory in readiness for those warm evenings (Har Har!). This system was (hopefully) going to sound as good as my main system - Squeezebox Classic > TC-7520 (modified) > DIY M3 Headphone Amp > AKG K701 Cans.
    Enter the γ1 (gamma 1 http://www.amb.org/audio/gamma1/ ) which I had read about a while back. It seemed to fit the bill - USB, Coax and Optical inputs, compact, USB or wall wart powered.
    So I went for it.
    Cheers - Ken
    You kept that one quite kensome pics please
    jon
    Quote Originally Posted by jon1 View Post
    jon
    I was always going to do a post about the γ1 - But when the bits started arriving, I got drawn into the build and, well, you know how it is ...
    OK, I'll take the γ1 to bits and shoot some pics.
    Ken
    - Albert Einstein.
    I'm john.
    Ken
    Yes you get addicted ken must get it finished...
    jon
    Basically, the γ1 can be built several ways - I chose to build the "full" version because I needed USB and Optical inputs. Depending on what you require decides what components or boards are fitted. This also affects the front and rear panel design.
    AMB sells pre-cut and etched panels for the full version, but they add $40 to the price - I chose to do my own... If you do this yourself, a vernier caliper is essential
    Here is the finished γ1 front and rear:
    The USB board can be configured to be a USB-to-S/PDIF and a USB-to-I˛S converter if you need it to be, which would require the population of the rest of the board as you can see:
    With the full version though, the USB board needs the DAC board:
    And then the two boards plug together to sorm a DAC butty:
    Here they are ready to be mated :
    Once they are together and tested, they can be installed in the case
    Front and rear panels are fitted and we are ready to play...
    The γ1 is a nice match for AMB's Minił portable headphone amplifier which I built some time ago. This is how they look together:
    Here is the rig in the conservatory being fed from a Sony CDP via the Optical out - The Minił is driving the K701's - Just needs the wallwart:
    And here the kit is attached to the USB hub and using USB power - The selector switch is lit green meaning the γ1 is receiving data - This changes to red on data lost or errors. The Minił is driving Senn HD600's (out of shot):
    There you have it
    This little DAC sounds really nice and VERY close to the TC-7520 - Just how close I will report when I have done some comparison tests.
    But for now I'll just enjoy a couple of these and some quality listening...
    Ken
    - Albert Einstein.
    If I were making another γ1 I would probably use a black Hammond case rather than the silver, but I had the Minił in silver already and wanted a match. Well, nearly, as the Minił has black end panels, but you know what I mean
    Oh, and BTW - It will be interesting to try the original 5V switcher with the γ1 that came with my Squeezebox - I didn't think about it, and bought another 5V wallwart (a linear) which is about 4 times the size and weighs several times the γ1!
    Ken
    - Albert Einstein.
    I'm john.
    Nice one ken..I see that sex had to creep in on your postPcbs mating..BTW nice pics
    jon
    jon
    Thanks, I do try to keep it clean Jon - It's just the interlocking procedure that seems to send me off on one
    - Albert Einstein.
    I'm john.
    Ken you do not know what members are doing behind the scenes..Like your self quietly building dacs..now enjoy it
    jon
