Does anybody know whether a MF Clic can access itunes on a home network?
In other words will a Clic downstairs in the lounge work itunes in an upstairs bedroom.
Just to add confusion the computer upstairs is using Powerline Adapters.
Kev
Manual says no.
Chris
Common sense isn't anymore!
Thanks Chris, that's what I thought but it seems a bit of an oversight. Lucky I'm only on the "C's" ripping to itunes.
Kev
What kind of machine are you planning on running as server?
I use a Zyxel NSA310, and it can perform DLNA, iTunes, and Squeezebox server duties.
It's not expensive to buy, and it's cheap to run too (17w when being heavily accessed).
http://www.amazon.co.uk/ZyXEL-NSA310.../dp/B005LDM09U
You'd need to get a decent HDD too ...
http://www.amazon.co.uk/Western-Digi.../dp/B008JJLW4M
Chris
I was intending on using my PC, I use this for a bedroom/study system. I was trying to kill two birds with one stone.
Kev
