I very much doubt there will be any unbuilt stages in three years - but you never know.
I'm Deleted.
Account Deleted
I'm Deleted.
I'm Deleted.
I'm Sandro.
wow 2 treads about the Paradise in this forum
I have the R2 boards for quite same time and I am in the process of populating the R3 boards I bought 2 years ago
It is the best phono stage I have heard but I think I can be made to be even better.
One thing I do not like is the lay out of the power supply
There are same transistors under the heat sinks and that get pretty hot that could do whit same improvements
The second thing I would look at is the servo same what of an improvement have been made by upgrading the op-amps
I would like to see, I don’t know if this is correct, a second order version meaning 2 cascaded filters.
I am handy whit welding components and drawing Circuit boards but can do whit same help whit a betterer servo.
I must say
I have not listened to it whit the Calvin buffers so servo may be not so important.
I have seen £750 for cost of build compared to what is on the market for that price I can say that in terms of speed nothing get even close to the Paradise
I don't think the servo is audible, but I guess that depends on how much it's working. Match the input stage and current mirrors to better than 1%, isolate the input stage thermally, and the servo should have almost nothing to do. I know in the units I build i seldom see the servo opamp doing any heavy lifting. Also a swap to a OPA627 or other low DC offset/drift op-amp can improve things over the standard part. If you think that DC drift is a concern and are worried about the servo I'd tackle it at source and do all you can to eliminate the offset before it happens.
I'm Sandro.
I must agree whit you that to eliminate the cause is better than having to use a cure, still a better servo would not hurt....
How much?£££££ OPA 627
25 quid each.... And the difference is tiny.
I'm Deleted.
I put them in mine back when it was fist suggested (aided by the fact that Si had installed ZF sockets for them in in the original build (they weren't quite so expensive back then - but still not cheap)). Anyway, I thought they made quite a clear beneficial difference back then - not massive but audible.
Account Deleted
