Hi all.
Someone on here had one of these but I can't find the thread...
Does anyone know of this company and it's HI-Q balanced stage? - How it sounds?
Many thanks
Joe
Hi all.
Many thanks
Joe
I'm ChrisB.
It's excellent.
Hi-Q were based in Lincoln and Nigel in Chantry Audio used to stock their gear. I think they mostly made custom pro gear. I can't remember the name of the guy I met a few times, though we did once seriously speak of the idea of them making me an all-valve 3-way active crossover - dem was the days!
Cheers Chris.
I may try one... I found the thread in the end with one being discussed by your good self. So what happend to the guys? I am a little concerned with the configuration of the load switches inside, nobody knows whats what with them. Do you know or anyone else?
I'm ChrisB.
I'm afraid I don't know. I half remember that thread - did I suggest that HiFi Dave or DSJR are friends with Nigel, who has retired to France. And that maybe contact could be made through that avenue? I expect Nigel will have a better chance of knowing how to contact the Hi-Q folks.
Nice one. I'll ask Dave unless he's loitering about here..
Nah then, Dave! You there me ol sunshine?.. lol
You'll be able to work out the loading by following the circuit traces.
If it's Path Premier Nigel, then hifi dave may be able to help possibly.
I'm ChrisB.
I was sure one of you two guys said they were still in contact with Chantry Audio Nigel in France?
I'm Nigel.
Joe,
I have the Iota Median balanced version, a 3 box design which is made up with box 1 power supply, box 2 adjustable MM stage, box 3 adjustable MC stage, very good imho, happy to let you try it out if you wish.
Nigel
I have the manuals with all the dip switch settings
