I have had more time to critically listen to my system of the past months, and guess what happened?
I like it less than I thought. The piano has an abrasive edge, trumpets also grate – more apparent at medium volume, so it always came down. I was suffering from listening fatigue.
In the last months I started the upgrades (after reading much here and elsewhere). First with the DAC (Bushmaster), then PSP, interconnects and speaker cables from Mark. The DAC and PSP did make a BIG difference, the cables also made a difference but less obvious with the current system.
Though improved, I still can’t happily listen to piano (e.g Kieth Jarrett or George Winston), or instrumental .
Im So Sad. That was a difficult admission – I didn’t realize how much enjoyment I had lost compared to an earlier system. (A long time ago I had Genesis speakers with inverted dome oil filled tweeters – never had listening fatigue)
So what is left?
That leaves the NAD C340 amp and the B&W CM2 speakers as the main culprits. – I have read some reviews indicating both can be fatiguing (CM2s have metallic tweeters)
What can I replace them with that is the ‘least likely’ to produce listening fatigue?
I am prepared to upgrade both Amp and Speakers – and I would like something really musical, mostly to play music like Jarrett, Winston, or Michael Hedges (Aerial Boundaries) or Ottmar Liebert.
So Doctor, your help please, what are the most musical, engaging amps/speakers you could recommend? I want to get goose bumps listening to my music again! without listening fatigue!!
I have a budget of about 600 to 800 GBP total (but I don’t have to spend it all!!). Appreciate your suggestions!!
