I have owned my Musical Fidelity KW 500 Dual Mono Integrated Amplifier from new in 2004. The amp and power supply were fully upgraded and modified by John Sampson at JS Audio last year and never sounded better.
The main amp went back of to John last month as the right hand channel output current resistors in the power amplifier (the amp had started to get as hot as hell and was just too hot to even touch briefly, though the sound wasn't affected). Whilst being repaired further Upgrade Work was carried out - both the Pre-amp & Power-amp Power Supplies within the main amp were further upgraded [this was following an issue identified recently by Musical Fidelity themselves]. Also a couple of capacitors in the Input Stage were swapped out. On getting the amp back I was blown away once again.
Anyway here is something that is beginning to bug me more and more as I listen to music using my Dual Mono Integrated amp . Conventionally we plug the left and right hand speaker cables into their respective left and right hand connections as labelled on the back of the amp but is this correct? The more live recording I listen to and the more I am convinced that this possibly isn't correct at all. I have been to numerous live concerts where the lead guitarist stands on the left of the stage (predominantly staying to the left of the band during the majority of a concert) and therefore he is on the right hand side of the band as the audience sees and hears things. However when the live recording is played back that very same guitarist now appears to be standing to the right of the band and the sound coming from the speaker on the left of the room as the listener looks and listens to the speakers. For these live recording to be anything like remotely accurate the channels would need to be swapped around so that guitarists that stand on the left of the band come out of the right hand speaker so as to mirror what was happening at the actual concert from the audiences point of view. Just like looking into a mirror, left is the audiences right and vice-versa.
Your thoughts would be welcomed.
Thanks,
Paul
