Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Some advice please...
    Forgot to mention that i also have an EMO broadcast phono stage that i've been playing with. It's quite good but i'm not sure how it rates alongside newer designs.
    Has anyone come across these over the years?
    Hi Al,
    Never heard of the EMO, I'm afraid. What's its history and connection with the broadcast industry?
    The question is ...do i want something i can put on a shelf and look at, and possibly modify?
    Or do i want something small enough to nail on the back of the turntable.
    More decisions!
    My advice is to go with whatever sounds best within your budget - audio performance is what matters first and foremost!
    Since this is only likely to be a stop-gap solution I wouldn't get too hung up on looks or the type of case used... Experience tells me that these devices which are only available in Japan (or the US) usually outperform many much more expensive units for sale on the UK market.
    I think the PEQ3 would be an ideal choice. The quality and value for money of AT products such as this is almost second to none. I reckon it will be a veritable little giant-killer!
    This Thorens unit also looks good on German Ebay:
    http://cgi.ebay.de/Thorens-MM-01-Pho...3A1%7C294%3A50
    Can you tell that I'm used to searching for items a little bit outwith of the mainstream?
    This is the same model i think.
    Mine looks like it fell from a third floor window, which i why it only cost me a fiver. But it still works ok.
    http://www.canford.co.uk/Products/21...d-XLRM-outputs
    Just because its built like a tank and retails at £200 , don't necessarily mean it sounds as good as a hifi box.
    Once i've established just how good this is, i can decide on what to buy. Tony has a Pro-ject box I can compare it to, sometime soon.
    First impressions are that its a bit bass shy compared to the little £12 box, but superior otherwise. Difficult to tell with a beat up old Connoisseur turntable.
