I'll settle for a painless one at moment.....Motherwell aint very far and if there is not much walking would probably manage......worked for DER there for a while in the 80,s....
No, your beresford/m2tech shouldnt be doing that.
I had the beresford and all the inputs were completly seperate from each other.
I didn't have this issue...know the Young didn't do that.
StanB is a good guy, he'll advise you on this I'm sure.
cheer, thought that but was not sure....either the m2 is totally overpowering the switchgear or their is a fault in the dac....It has had all the mods done so it might be related to that....sounds bloody good though so was going to try and find a coaxial switch so that I dont have to unplug the highface when i switch to the cd player or dvd player.
sure I saw something in maplins once apon a time...
will keep an eye out for stan b..
The new 'Orange' M2Tech HiFace dac is superb ,24/384 asyc USB , and not expensive.
Keith.
Cessaro Horn Acoutics,David Wright ,Mola-Mola , Weiss MAN301,Dynavector XV1- Manger Loudspeakers Grimm Audio LS1,worlds best sounding loudspeaker.
Mini DSP digital signal processing.
www.puriteaudio.co.uk
I saw that being advertised in the dealers bit and it looked good...I also have an HRT streamer 2 usb async dac and I like it a lot..it is on my 1st system...got it cheap or would have gone for the new hiface.
Thats user name StanleyB by the way, here on AOS.
Stan Beresford, who designed the dacs.
Nice point Gary...I better be polite .....a clever guy...thanks for the info.
I use a DCD 1520 in the office system and this is the transport for the ton-up Digit Opto I've been using for some time and also the new little pretender I mentioned earlier. The 1520 isn't really a slouch sonically as a complete CD player, apart from the fact that I believe it inverts the phase of the output and this I hear as a 'flatness' of perspective. Twinning the supplies to the Digit made a heck of an improvement to the extent that I maintain that even humble IC op-amps really do need a clean supply to sound transparent. The fact that these op-amps go wide out to MHz has got to have something to do with it, but I'd be delighted to be proved wrong here as it's supposition on my part...
Anyway, I know and highly respect the Rega DAC, but didn't mention it before - I wonder why? and I've always loved the original clamshell Planet, despite its awkwardness in use compared to slicker competition.
Are we talking about a BM here, and if so, do you have two or more active digital sources plugged into the BM at any one time? If so the BM won't buy it, you will need to switch off all sources other than the one you are listening to. The control circuitry gets confused when it is seeing two or more active sources which can spurn some odd behaviour.
