Now then,
To get a bit more DIY on the amplification side onto this forum, I thought I'd better introduce y'all to a nice little Single Ended amp.
This one is based on the National Union 46 dual grid power tube.
Strapped as triode, it puts out about 1 watt per channel. Now this might be seen as a laughably low power output, but with 100dB efficient open-baffles or horns there is sufficient welly to rattle the windows in a typical British living room.
It is a direct-coupled reactance drive amp based on Jack Elliano's and Jeremy Epstein's designs.
Here's a schematic:
The input/driver is a 12AT7 directly coupled to the grid of the 46.
Looking at the schematic, you can see that there are only four components in the signal path excluding the volume control and valves.
Amps dont get much simpler than this.
The reward for all this simplicity is a lovely musical sound, with gorgeous detail and that nice glow you get from valves.
Heres a pic of the amp itself:
Of course it won't work in the majority of systems, but if you are running efficient baffles or horns, it is a lovely experience.
Trouble is it might just usurp the bigger PX25 SET amp and kick it out of the system.
Steve
