I don't think this has been discussed here before, but the Computer Audio Design website has a lot of very useful information regarding setting up and optimising a Windows 7/8 computer for audio playback.
Computer Audio Design sells the above high end DAC which I have no experience of and if any one is interested, you should check the site out. Its certainly very stylish and I really like the design, however, this post is mainly to assist people who may want to improve their Windows audio player, but don’t really know where to start and are maybe a little intimidated about shutting down services or poking around in the registry. There are some very handy guides in this section, which you can check out: http://www.computeraudiodesign.com/computer-setup/
In addition to the guides, there is also a script which you can run on a Windows 8 machine, which shuts down and disables a large number of services and drivers in the operating system. It should be noted that unlike Fidelizer, these changes are permanent and remain on the system after a reboot and are intended for use on an audio playback only computer. You can of course go backwards and turn the services back on and there is a script on the site to do this too. If you use the script on a general purpose computer, it may not function normally, so make sure you understand this before running the script. Additionally, it is also very important you take steps to carry out some simple safeguards to your system, by making either a full backup or disk image (recommended), backing up the registry, creating a Windows system repair disk and at the very least creating a System Restore Point. After you create a system restore point, ensure you reboot your machine before running the script. If you have never created a Restore Point manually before (it's simple) there is a guide from MS here: System Restore
I have mentioned it before, but with the low price of small hard drives for the O/S in a music server, it can make sense to have a spare. I have two, a primary drive and a test drive which is a clone of the original. The clone is where I do all my testing, so if I mess it up there's no harm done and I just slot my original drive in, so I can still play music. When I am happy that any changes are both worthwhile and stable, I them implement the changes to my primary drive. The script is also open source and can also be found on the website. To allay any possible fears about running a script, I have opened it and read through it and you can do the same using a program like notepad, to review all the changes being made.
I think this is fantastic work from Scott and goes a long way to helping people get the most from their Windows machine, with very little effort. It was one of the things I was in the process of doing for a blog, but he beat me to it.
Finally, just a quick thanks to CAD for doing all this work, for making it open source and for allowing me to reproduce it on AoS.
Tim
NB: Just a final reminder, please ensure you take the safeguards mentioned above before implementing any changes to your system. If you are unsure how to, just Google them, there are numerous step by step instruction guides for everything I have suggested
