Originally Posted by
selby
Are HD Tracks worth it or just a marketing thing?
What is really important is the mastering, not the format by itself. With the same master, any difference between 24/48 and -say- 24/96 will come from the downsampling software used. Usually, professionals have better downsampling algorithms than the ones you can find in mainstream dacs and home media players.
HD tracks does a good job, but others do an equally careful work : Rhino, for instance.
There are plenty of exceptional masters produced by the mainstream editors : Sony, EMI and so on : rarity is not an equivalent to quality in this matter.
selby
What player to use on a Mac? Audirvana / Amarra?
If HD is just marketing tosh, then what's the next best thing? SACD? CD Ripped to a lossless format?
Any feedback from your trial and errors would be great.
I don't owe a Mac, but most of my (sound-demanding) friends use iTunes or Audirvana.
SACD is another matter alltogether: the biggest advantage of this format, when it first came out, is that it could be playbacked by entry-level hardware (costing pennies) while producing exceptional quality sound. In the meanwhile, PCM D/A converters became better and cheaper, so, today the difference (if any left) is not worth the trouble.
Stick to the basics if you don't want to go wrong : the most important is the mastering, not the format.
Dimitri.
George Orwell
