Hi All,
This is my first attempt to post pics of my set up. If it doesn't display properly please be gentle with me.
It obviously does not bear comparison with some of the kit that most of you guys seem to have but it's the best my budget can run to.
I have attempted to put them so that they display the left side to the left and the right side to the right, so as to make a disjointed panorama - sorry about the TV picture but the Budget Controller is a keen fan of Countdown !!
The heart of my system is a Marantz PM6010OSE KI amp in the centre of the shelf under the TV. To it's right is a Marantz CD-63 mk II KI player and above which is a Sky HD box.
To the left of the amp, on the bottom is a Sony BD350 Blu-Ray player, above which is a Sony MM PC, a Vaio VGX-XL201. Despite the close proximity of everything I have never had any suggestion of anything overheating (so far !!). Note the precision centre support under the bottom centre of the wooden unit - the weight began to take it's toll so a 'prop' was installed.
The speakers are MS Mezzo 2s in oak. At the moment the speaker cable is a bi-wire set up cobbled together by me from an internet posting (saying they were as good as any much more expensive cable) from solid core Cat 6 ethernet cable (budget again !!). I have recently bought off eBay some QED Silver Anniversary cable and plan to swap them soon - opinions on whether I will notice any improvement would be welcome and I will let you know after swapping.
The Vaio and the CD player both communicate with the amp via solid silver interconnects from 'johnandchris' on eBay. At the moment the Blu-Ray player is coupled only to the TV, using the HDMI lead - it used to be optically connected to a Marantz SR4001 AV amp which in turn drove my SS speaker set but the SR4001 and SS system had to go to make room for the 6010OSE amp.
I would be happy to receive ANY comments, criticisms and suggestions about this set up, providing they are polite and intended to help me get the best out of what I have got. Of particular interest would be suggestions on what is/are the weak link(s) in the set up and how they might be strengthened without adding to the national debt too much.
I have around 2,000 FLAC files onthe PC and my next intention is to get a DAC to put upstream of the amp to see what can be improved. Again comments, advice and polite suggestions would be appreciated.
I look forward to hearing from you - a novice like me cannot get too much advice but I may not always be able or willing to follow it - please don't let this stop you from profering it!
Dave.
