Just setting up a new PC and was wondering if anyone is using Exact Audio Copy with Windows 8 as it doesn't show yet show as a compatible O\S on the EAC website which seems odd as Win 8 has been around for a while.
I'm RichardbutpreferRich.
Rich
Source: Squeezebox Touch, Chinese AK4396 DAC, Pioneer PL-112D + Shure M75ED type2, Pioneer PD-7700 CDP
Amp: Sansui AU-505
Speakers: Ditton 44's
Thank Clive, I've installed the latest 1.0 B3 version and it seems to be working and rips all tracks from the CD OK. However it's not creating a seperate folder for each album at the moment and so I will need to do some research on the net as configuration of this latest version is a little different from my old one.
Rich
Amp: Sansui AU-505
Rich,
Try this naming scheme in your EAC options under 'Filename' - %albumartist%\%albumtitle%\%tracknr2% %title%
This should do what you need
Cheers Tim you are a star, worked a treat
Rich
Amp: Sansui AU-505
Took me a bit of tweaking to sort it myself Rich when I upgraded my EAC to 1.0 b3 - why do they always have to change things around
I could not get it to work on win 8.....would not recognise a cd when put in.....so just ended up using it on my older vista machines only...
