Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Pete's Lenco GL 75
  1. #21
    I'm Peter.
    There's one up now and I can see the long trailing wires in the picture
  2. #22
    I'm Peter.
    Well, arm bought, bodged in and no sound - apart from a loud hum!
    So, I'm very frustrated and not thinking straight.
    I'm learning very quickly that I am not very good at DIY!
    I have two problems - loud him (probably a rubbish connection between the ground wire an the arm)
    - no sound! Probably wired it in wrong.
    I know nothing about tonearm wire. I'm not sure what to do now or how to explain the problem. Will try again tomorrow when I can think a bot more dispassionately about it.
    Grr!
  3. #23
    I'm Peter.
    Well, I've fiddled and bodged a bit more with no further results. Just the humming (which gets much worse if I decouple the wire that connects to my pre-amp).
    So, I'm out of ideas and beyond the extent of my knowledge and common sense.
    I should admit here what I mean by 'bodge'. The only thing I have to connect loose wires is sellotape. So, that is what I have used to connect the wire from my arm to the wire that is already in the machine and connected to the bit which connects to the phono plugs.
