Results 1 to 5 of 5
Thread: which rack for a gyrodec ??
    Default which rack for a gyrodec ??
    LO ALL..... My soundstyle 4 tier rack is getting long in the tooth (yeah yeah ) Apart from that its a postbox red metal frame with 40 mm dia legs with 4 smoke glass shelfs. I think it wasa xs100 or something.
    anyway the top shelf was never really wide enough for the deck to look comfortable. Hence I need a new un.
    Its looks aint as important as the sound ( note suspended record player )
    but I can't have a pig in the house ( got one allready....OUCH ! )
    A seismic sink is out of my price range at the mo so any ideas.
    Do quadraspire still do thoso modular ones for instance ?
    I'm calling on anyone who uses a good shelf system to talk to me and say why theirs is good or bad ! cheers guys ,and guyesses if any are out there.
    ps 4 tier minimum as I want the pre and power amps two shelfs away from .each other
    _________________
    Hi Ivor,
    Give me an idea of budget and I'll see if I can help
    I'm Neil.
    Hi Ivor
    I would wall mount it. In my opinion that will give the deck the best environment to work at its best. Try Custom Design, for cheapest best options.
    Regards D S D L
    Regards Neil
    I agree - wall mounting, if possible, is the best idea for a turntable. Custom Design are good, like Neil says, and one of these would also work well:
    http://www.audioaffair.co.uk/index.p...&productId=584
    I'm Neil.
    This Target wall shelf at the end of Marco's link is a great one too...forgot about Target.
    Regards D S D L
    Regards Neil
