I need to replace my AT OC9 ML II. Some things it does well, but the things it doesn’t do quite so well are frustrating.
On joining this forum I mentioned in my intro that in the chain of LP12/Ittok/Icon Audio PS 1.2/Musical Fidelity A5cr Pre and Power/ProAc response D28's it sounds a little too hard and bright: lot's of incisive detail and clarity which I want to obviously keep but the background harshness has to go on my next cartridge. A little more bottom end weight and warmth would also be welcome.
I’ve had some useful guidance and suggestions from forum members, but I now need to move forward with a short list.
1 Benz Micro Ace S L (Seems to review well everywhere)
2 Dynavector DV20X2 (Looks promising but has been described as “possibly dull” – admittedly on a new example. Also described as “Dark” – anyone explain?)
3 Audio Technica AT 33EV (Would I get more of the same as it’s another Audio Technica – or how much better is it than the OC9 (if at all?))
4 Ortofon Cadenza Red (Top end of what I’d like to pay and looks a b*gger to connect – would need a compelling reason to go this route)
5 Benz Micro Glider – if I’m up at Cadenza Red money this comes into play: but is it just a naked Ace?
If anyone can quantify the sound qualities of the above it’d be a big help to me – especially if in comparison to each other. Even better would be their listening experiences in relation to the OC9 II.
Shelter 501 was also suggested but there doesn’t seem an easy route to get one of these except via Hong Kong which I have no issue with but it’s “fiddly” by comparison. Would the effort be worth it and does it blow the rest away?
I’ve not been able to listen to any of these so the list is just from reviews (dangerous – the OC9 was bought on the same basis) and comments (personal preferences come into play and we all tell it differently because we like different things). It’s also just one item in the chain and has to fit with the arm / phono stage etc.
As it’s so difficult to demo cartridges now, I guess this is about the only way to narrow things down a bit: views are welcome.
