I thought there was a sticky thread, but can't find it now.
I'm gone.
I'm stu.
Goldring did a very nice job on the koetsu i'am using.
Dom at http://northwestanalogue.weebly.com/ is great.
Soundsmith if you are patient
I'd love to see some actual data on who is the best. Who gets the most solid bonding of stylus to canti, closest to the original tip mass, most accurate alignment, greatest lifespan after re-tipping, all that jazz.
I'm scott.
Dom from northwest , len @ the cartridgeman , soundsmith , goldring , ESC
( in no order )
If you only played jap vinyl, I suspect your request would be the other way round
I'd recommend EsCo if you can wait and I've used them myself in the past, since they can do almost anything to cartridges, rebuilds etc., as well as manufacturing OEM styli, grafting broken cantilevers and fitting new diamonds on to existing good cantilevers. I understand that many styli come redy bonded to cantilevers, only needing trimming and carefully bonding to the coils/magnet. This does save a lot of hassle..
Plus 1 more for EsCo.
I've had a couple of 103's that they built for me. Well worth the wait
Ian
http://www.hifisounds.co.uk
Photo bucket - loads of mods!
SL1200- DIY PSU- DIY FET int regs-Denon DL103 by Expert Stylus Company on Isokenetic stabiliser & Sumiko HS-12 shell- Achromat - Isonoe feet, Meridian 200 Phono satge, Junson JA-88D, Audio Aero Capitole CD/ DAC, extreme modified Marantz SA7001, Squeezebox Touch modded to death!, Focal 826WSE- Kimber 8TC, Kimber and CAT5 attenuated DIY Interconnects, Kimber mains
"Leave Nothing as Standard"
Is there an internet link for EsCo - Google is not coming up with anything?
