Originally Posted by
Jimbo
Hi Martin, I have to agree with some of the other posts that Glue is indeed expensive, time consuming and messy. Do you still have the MOTH RCM and does it do a good job as I would seriously consider buying one.
Yes I still have it and would wholeheartedly recommend it, I don't think there is anyone here who uses one who would not do so. The Okki Nokki does seem to be available slightly cheaper and again, no-one here who owns one has anything less than praise for it.
I had a reasonable collection (about 400 LPs) that had languished for many years due to scratches, stickimg, jumping and general noise. All those things that people say puts them off vinyl. With the vinyl revirginizer I cleaned a couple of records as test and it was jaw on the floor time - not only had it cleared up the noise, sticking and jumping, it had also improved the overall sq particularly in the high treble. That was when I bit the bullet and bought the Moth.
I now have many, many LPs that play as cleanly as a CD with absolutely no surface noice, pops or clicks. Records I bought as a teenager are rendered as new, my whole collection was opened up to my appreciation again, not to mention the hundreds of Lps I have since bought for peanuts second hand.
One last thing to consider - I don't remember the last time I had to clean the stylus - it must be well over a year ago. If you are using anything other than a twenty quid 'Saturday night special' the savings you will accrue in extended stylus life alone will pay for the RCM within a couple of years.
Regards
