Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 68
Thread: Thing's GL75 Project
  1. #41
    Quote Originally Posted by The Grand Wazoo View Post
    3.7kg
    According to the owners manual it weighs 9lbs which is 4.08 kgs.
    http://www.radio-workshop.co.uk/goldring-manual.shtml
    In - Tweaked Lenco GL75, Linn Ittok, Ortofon Cadenza Black
    Through - Croft Micro 25 RS LS, power R monoblocks, RIAA R. Ortofon ST-80 SE SUT.
    Along - Tellurium Q Ultra Black cables
    Out - Harbeth SHL5 Plus XD's
    Street photography
    Dave
  2. #42
    I'm ChrisB.
    Oh, OK - I stand corrected.
    Perhaps the G99 platter is a little lighter then? It has machining for strobe markings but I don't think that would remove a pound in weight, especially as it's slightly offset by the fact that the balancing holes are filled in the G99.
  3. #43
    I'm stu.
    Ok thanks.
    Was wondering if 1 platter and a copper mat might get a similar effect?
  4. #44
    Quote Originally Posted by chelsea View Post
    Ok thanks.
    You don't have to use 2 x lenco platters Stu. There have been many projects that have utalised platters off diferent decks, acrylic, glass and the like and various different mats.
    What we are trying to achieve is mass. Someone even tried 3 x lenco platters... It did look a bit tall but it was an experiment.
    I don't know how heavy the copper mat is but it may be worth trying?
    If you have another turntable platter availiable just lay it on top of the Lenco one and have a listen. I tried with my LP12 platter that's how I initially knew it was the path I wanted to take.
    I chose to use 2 x Lenco platters just for convenience and the fact I got one off fleabay for £9.99.
    Street photography
    Dave
  5. #45
    Not sure Chris. I'd weigh one of mine but I don't have any bathroom scales at present...
    Street photography
    Dave
  6. #46
    I'm ChrisB.
    I've never owned a set of bathroom scales - maybe that's why I'm a fat bastard?!
  7. #47
    I'm Keith.
    Default Re: Thing's GL75 Project
    Quote Originally Posted by Thing Fish View Post
    I 'm pretty sure it's 4 kgs Keith.
    Aye, 3kg was from memory. Now I'm back home, I've popped my GL75 platter on the kitchen scales - and it weighs in at 3.8kg.
    Keith
    Analogue: Lenco L75 with 'PTP5' top plate in heavy birch ply plinth/re-wired Rega RB300/SAE 1000e HOMC Cartridge/Trans-Fi Reso-Mat/Moth RCM
    Files: Voyage MPD/Custom PC/Supra USB/Beresford ASYNCH-1/Beresford TOSlink cable
    CDP: Inca Katana SE
    DAC: Beresford Caiman MkII (LiPo Battery powered)
    Pre-Amp: Croft Micro 25 Power-Amp: Croft Series 7
    Speakers: DIY Frugel-Horn Mk3 ('FH3') + REL Strata subwoofer
    Headphones: Beyer Dynamics DT990 Pro (250 ohm)/Schiit Asgard Headphone Amp
    Cables - Interconnects: Mark Grant G1000HD Speaker Cables: Van Damme Blue
    Mains: Belkin PF30/Mark Grant DSP2.5 & DSP1.0 Rack: Target
    Office System: HP Win8 Laptop/JRiver/MF V-Link2/Beresford Bushmaster MkII/Topping TP20 Mk2/Mission 771e
    Bedroom System: Raspberry Pi/Raspbrian + MPD/HiFiBerry DAC/Topping TP20 Mk2/Mission 760i or DIY Hybrid Valve-MOSFET Headphone amp + Sennheiser HD595
    Gallery
  8. #48
    I'm Paul.
    Ok thanks.
    Dave's right, you can use anything - I think I read on LH that someone makes the kind of heavy mat you've suggested above as an alternative to a 2nd platter, or for those who don't like the idea of an overly tall platter.
    I've currently got my standard Lenco mat sitting in between my 2 platters, the spindle extension gives you quite a bit of extra height to experiment with.
    Paul.
  9. #49
    Looks good, Dave, but there's not a lot of spindle clearance there!
  10. #50
    I'm Nobody.
    Thats the effect you would get with a 'L70' platter with rim machined orf
