Very good cable, no longer needed by me but by no means a knock to it, I love AQ cables and use them throughout my system, I simply just have ones now further up the range made out of solid silver rather than these which are copper.
Terminated with bananas, 2 at amp end and 4 at speaker end
There are tons of great reviews around
RRP was about £225
Looking for £65 plus £5 postage
heres a load of blurb from the manufacturers website:
At first glance, Type 4 looks like a normal round cable, but inside is a fully optimized and very sophisticated balance of quality
ingredients and refined design.
CONDUCTORS: All four of Type 4’s conductors are solid. Electrical and magnetic interaction between strands in a conventional cable is
the single greatest source of distortion, often causing a somewhat harsh, dirty and confused sound. Solid conductors are the most
important ingredients enabling Type 4’s very clear sound. Whether a conductor is solid or stranded, skin-effect is a prime distortion
mechanism in speaker cables. Type 4 very simply keeps this effect out of the audio range by using conductor sizes that are below the
threshold for audible distortion.
LONG-GRAIN COPPER: Type 4’s LGC (Long-Grain Copper) allows a smoother and clearer sound than cables using regular OFHC
(Oxygen-Free High-Conductivity) copper. OFHC is a general metal industry specification regarding “loss,” without any concern for
distortion. LGC has fewer oxides within the conducting material, less impurities, less grain boundaries, and definitively better performance.
All drawn metal exhibits directionality, whether in hardware store wire or in the best AQ cable. We wish we could design away this
awkwardness. Since we can’t, we pay close attention to optimizing performance by clearly marking the cables and our terminations.
Please watch for these markings when installing any audio cables.
GEOMETRY: The relationship between conductors defines a cable’s most basic electrical values (capacitance and inductance).
However, even when those variables are kept in a reasonable balance, the relationship between conductors can be varied in ways that
greatly effect the sound. The spiral construction of Type 4 allows for significantly better dynamic contrast and information intelligibility
than if the same conductors were run in parallel. The specific 4-cross geometry used in Type 4 maximizes this advantage.
INSULATION: In a low level cable the insulating material significantly affects the cable’s performance. However, in a speaker cable the
electrical effect of insulation is almost only heard as a dry irritating sound prior to a cable being fully “run-in” … technically “adapting to a
charged state.” The term “break-in” does not apply because taking away the charge will slowly return the cable to its “new” condition.
The insulation’s mechanical (hard vs. soft) properties make an important difference in stranded cables. The harder the better in order to
minimize strand movement. Since solid conductors don’t need hard insulation, they can take advantage of the vibration damping
advantage of a softer insulation.
SST (Spread Spectrum Technology): Any single size or shape of conductor has a specific distortion profile. Even though radially
symmetrical conductors (solid round or tubular) have the fewest discontinuities, any particular size does have a sonic signature. SST is a
method for significantly reducing the awareness of these character flaws by using a precise combination of different size conductors.
SST has enabled Type 4 to be the biggest possible four conductor cable that avoids audible skin-effect. A combination of these major ingredients,
and many more subtle details add up to explain how even an affordable cable like Type 4 can sound so good.
