I remember a big thing about mains "conditioning" around twenty years ago. At the time, I lived in Luton and the mains there was cr@p of the highest order (the place wasn't much better, but that's another story).
I had a Deltec PDM1 mk2, which sounded scrappy without a mains filter of some sort. Apparently, the unit itself had a noisy supply or summat and this was why a filter was needed IIRC.
Later, I experimented with cable "ferrites" to good success and "imagined" the sound was cleaner and more musical in the bass with them in situ. I read an article by ben Duncan stating that the rating of a pi-style filter (as appears in this mains block) should be ten times that of the item to which it's connected. I used a 4A rated filter made by Glenn Croft on my CD players in later years to good effect. The AVI preamp was immune to mains difficulties but the ATC actives seemed to like ferrites on the mains leads - home made with soldered 16A rated cable and MK 13A fused plugs on.
The Chord Company marketed a £200 6A mains filter for a while called the "Clearway." Shunned by the "in-crowd" it actually worked well on my CD player and tuner (one on each!). Linn sources and preamps with SMPS benefitted from one on each item, minimising interaction between them (a Karik/Numerik was a MUCH better combo treated this way, but the CD12 didn't mind either way. A Naim Supercap didn't sound any different either in the same environment). I later discovered that the Clearway lives on as the sub £40 Roxburgh filter available from Farnelll UK.
In our current coastal location, despite the fact that one of the biggest European ports is a mile or two down the road, our mains is clean and these filters have little or no effect. I still keep one on the CD player, as those old Philips 16 bit chipsets/players can spray a lot of rf and ultra-sonic muck into the mains and down the screen of the interconnect (one reason why the transformer coupled balanced output sounds so much better than the original CD94 based SE output, which sounds closer to the balanced if ferrites are used).
Sorry to hi-jack the thread, but hope some of this helps and explains why Mr Dalek [Chronicles] Emperor () suggests leaving the power amps off this mains block, which sems a good buy for source components used in a noisy mains environment.
