Good luck mate . I was listening to my system tonight before work and IMHO it's a no brainer . Sounding very good indeed. Please keep us posted Chris.
Chris
I'm Stephen.
Have had the same thing done in my listening room, except I had a seperate CU fitted for the hifi and kept the house on its own
A fair bit of the 'upgrade in sound' can probably be attributed to the fact that the incoming fuse is removed and replaced - which (obviously) has a cleaning action on the contacts. In my case (again) the sparky thought I was bonkers asking if I could clean the fuse contacts before he replaced it back in the holder
If you want to go the 'whole hog' say your having a 10 - 12 Kw shower fitted and ask for a 100A incoming fuse - lower the resistance that last bit
Your correct in saying no C/U's are the same as they used to be - they are way safer, and in some instances, much better!
Don't go thinking you need to have 32A mcb's fitted in every line of the HiFi feeds- internally they are all the same, just the measuing coils are differnt
Just my 2$c
I'm scott.
give the fuse endcaps a polish ,deoxit . lawson ME/MFamp good , uk made fuses
Thanks for the advice on fuses today Scott and thanks for the hospitality . Both myself and Gary thoroughly enjoyed our visit to yours and listening to your amazing dem system . Bit of an education for me really from a very helpful and knowledgeable dealer . The equipment you loaned us will be put through its paces in the next week or so . I will report back on my findings when I have some time.
Martin
Source: Sonos CONNECT DAC: Rega DAC Amp: Rega Brio-R Speakers: Neat Motive 2.
My system photos
I'm scott.
good to meet you brian , glad you had a nice day
I'm fuckoff.
To the op, did you use any kind of mains filtering/conditioning before/after the job?
