Roy K. Riches (sp?) is the only person I have found that is obsessive enough to have auditioned different consumer units, and the one he rated most highly is made by Memera 1000/2000 range, made by Eaton.
I have two, and they are certainly very good - no nuisance trips or other problems as I have experienced with some cheaper makes. It sounds very good too as I put in four MK double sockets, each on it's own circuit using 8mm sq T&E cable while I was redoing the lounge. Possibly overkill, but it wasn't too expensive as I had the floor up in the lounge. There is certainly no buzzes or clicks from appliances on the other ring mains and the noise floor does seems to be lower since this work.
Cheers,
A.
Technics SL1210| Jelco SA-750| Benz Micro ACE SM MC| Squeezebox Touch/MCRU linear PSU | Cambridge Audio 851C | High Resolution Music Streamer II+ / Linestreamer+ | Raspberry Pi 2/IQ-Audio DAC+ / Max2Play | Conrad-Johnson ET3 Control Amplifier| Conrad-Johnson LP125sa KT120 Power Amplifier| Avalon NP Evo 2.0 Speakers| Cardas Audio Quadlink-5C Speaker Cables and Interconnects| Finite Elemente Pagode Signature E-14 equipment support
