A few photos of RFC' latest commissions:
First up is a twin-arm skeletal plinth for a Garrard 401. It uses sorbothane mounting but the mounting platforms are also drilled to allow the deck to be bolted down and and as an optional extra, sorbothane damped arm mounting plates can be supplied. This plinth is constructed from 40mm Birch Ply veneered in European Oak. Legs are hand turned from European Walnut and fitted with 24K Gold plated adjustable feet. the base has 4 50mm diameter sorbothane isolation feet inset into it (out of shot):
Next up was a one-off build for a customer who wanted a solid Oak bedroom hifi cabinet. The drop down leaf is supported by solid brass guide arms and can support over 40Kg. The cabinet is 860mm wide and about 900 tall. It has a large isolation platform sat on top made from 40mm thick laminations of Birch Ply veneered and edged in Oak and sat on inset sorbothane feet. Handles are all hand made from European Walnut and the unit sits on high quality castors:
Drop down opening for amplifier storage. Cable cut-outs and ventilation can be seen on the back panel:
Close up showing wood finish (3 coats of oil) and walnut handle:
Isolation platform for source components:
If you would like a TT plinth, I can supply these for most turntables. For Garrad 301/401's there are two main designs. The one shown above (skeletal) with the deck flush mounted (very neat!) or solid stacked Birch Ply veneered in a timber of your choice. price dependant upon design/timber specified but prices start at £350 for a basic plinth.
Hifi cabinets can be supplied in any timber of your choice. Hifi racks also available. Prices for Racks and cabinets start from £500 upwards dependant upon size, materials and construction complexity. £500 would be for a veneered twin tier large hifi rack or compact cabinet.
Please contact me for more details.
You can view RFC's full range of hifi furniture by following the link below:
http://referencefidelitycomponents.c...ifi-furniture/
Simply click on the links on the Furniture home page to find out more.
