Thinking of changing phono stage to a microgroove plus from a densen dp04 has anyone got experience of either also if anybody selling a tom evans could be interested Thanks John
I'm john.
What's wrong with what you have?
I'm john.
Dave i thought the densen was ok until i tried a jasmine from china it sounded so much better in every way the thing is i would have to import it so that is why i was asking about the microgroove as it gets good reviews
I had a dp01 that I wasn't that impressed with - it did a decent enough job just not as good as a P75 that I had before. I went and tracked down another P75
I have just sold a Microgroove plus and can confirm that it is a great piece of kit. Good VFM. defo plays tunes.
I'm john.
I feel the same way about the densen its ok ,the p75 is that the dynavecter
I'm john.
Me so horny- Impulse H6 Horny
I'm john.
I'm Jo.
I have used a DP-04 and at the moment IŽm using a Mricrogroove Plus X.
The DP-04 is an extraordinary phono stage and a best buy in the 1000,--class and above. I have tried many phono stages in this price range, e.g. Heed, Sonneteer, Linn, Musical Fidelity, Trigon, GCPH, Aqvox etc.. In my ears the DP-04 was the best as well as better then a Klyne and very close to an internal phono stage of a DNM 3C Six
In my ears the Plus X is better but more expensive as well, but if someone is looking at the 1000,- class there is no better choice then a DP-04.
Jo
