A new product from Weiss,
The INT203 Firewire Interface can now be used as a digital volume control box!
The latest software for the INT203 Firewire Interface allows it to be used as an IR remote controlled volume control unit. This mode is activated as long as there isn’t any computer connected to the Firewire port of the INT203.
With the input selector two sources (XLR / RCA) can be selected. Both outputs (XLR / RCA) are active and can be used simultaneously. With the remote control the volume as well as the absolute polarity can be changed. A “Mute” key is also there.
The volume control algorithm uses dithering to a 24bit word length, which makes it a top quality method to control the loudness of an audio signal.
Put the new INT203 to use for any digital source which should be volume controlled ahead of e.g. the D/A Converter.
More information can be found here:
http://www.weiss-highend.
WEISS ENGINEERING LTD. - Professional and High-End Digital Audio Products
Florastrasse 42** 8610 Uster* Switzerland
phone: +41 44 940 20 06,** fax:** +41 44 940 22 14
email: weiss@weiss.ch****
web:** http://www.weiss.ch
****** http://www.weiss-highend.com
Asia:* http://www.asiaweiss.com
