Results 1 to 10 of 18
Thread: Speaker Cable
    Default Speaker Cable
    Can anyone give me some good suggestions for reasonably priced speaker cable or recommend cables they have used and have found them to be a worthwhile investment. I have been looking for some time now and obviously with sooo much stuff out there with so many reviews its difficult to see the wood for the trees. I am a bit of sceptic but do believe improvements can be made although it could be each cable just colours the sound in a different way.
    Any suggestions would be great.
    Alex_UK's Avatar
    Hi James - give us a bit more to go on - your "reasonably priced" could be "stratospheric" for others - what's the rough budget, and how much do you need (lengths)?
    Alex
    I'm Neil.
    Hi Jimbo could you tell us a bit more about your system too?
    Black rhodium twist at £3.50 a meter do not be put off by the small amount you pay per meter it won hifi speaker of the year for 2012.
    PRE
    I would have to recommend Mark Grant's cables and Mogamo cables. Having heard more expensive cables I can't justify the greater cost. Usually try and send back if you don't like them so I would at least start here. Give them at least 100 hours to burn in before making your decision.
    I'm Josie.
    Van Damme.. Very good, going to try the 6mm core stuff soon. Mark Grant sells and terminates it.
    Tannoyista.com
    - Audio Equipment Reviews
    Facebook
    I need 2 x 5m lengths. My system compromises of Rotel RCD 965bx/Gatorized Caimen, Quad 606 into Spendor SP2 speakers
    I'm Josie.
    The Van Damme 4mm LC-OFC stuff is excellent for long runs... Price is great too.
    Tannoyista.com
    Facebook
    I'm the'greatunwashed'.
    +1 for the Van Damme Cable - I use the 4mm Professional Blue Series Studio Grade, extremely well made and robust, used by the pros, very neutral and above all affordable.
    Sold by Mark Grant terminated or loose (recommended), also from Amazon. I would try MG first though who is a trusted member here and I have had nothing but good service from Mark in the past.
    http://markgrantcables.co.uk/shop/in...roducts_id=399
    http://www.amazon.co.uk/Van-Damme-Pr...0154790&sr=1-4
    I'm Rob.
    I like Supra Rondo 2x2.5 or 4x2.5, Kimber 4PR is very decent too.
