Results 1 to 4 of 4
Thread: The Decca 'Green' cartridge
    Default The Decca 'Green' cartridge
    After an enquiry made by a new member concerning the Decca ‘Green’ cartridge, the following might be of interest.
    The Decca 'Green' is a monophonic cartridge ‘head’ made by Decca as part of their ffrr / ffss range (from the Mk.I to the Mk.III designs).
    (Image: vinylengine)
    Vinylengine quote the following specification:
    Output: 7.5mV
    Response 20Hz – 20kHz
    VTF: 2 – 3g
    Recommended load impedance: 50kΩ
    Coil resistance: 4.4kΩ
    Spherical tip radius: 0.0006/7" (though according to a Decca leaflet, this radius is stated to be 0.0009")
    Compliance: 12cu (stated to be the dynamic compliance. I believe this is the static compliance, not the dynamic compliance.)
    Decca also state in their leaflet on ffss stereo heads, the following:
    Mono Microgrove Head
    The stereophonic heads track perfectly well on all monophonic/microgroove records in good condition. The mono microgroove head is produced for -
    (A) those who wish to use monophonic only system, or
    (B) those who have many of the older type of microgroove records which have been worn by a pick-up of poor performance.
    They also state the recommended playing weight is 3 grammes.
    Image no worky, daftee... You'll have to host it through your Photobucket or Imageshack account, rather than linking through VE
    Done.
    Cheers - that's better!
    Always remember that that is the best way to post images on the forum. It also prevents broken links developing later, which caused all that hoo-hah recently with Malware warnings being flagged up by Google
