I am in the process of renovating my Thorens TD160
Is there any way we could have a Thorens specific group so that everyting Thorens can be found in one group please ?
Cheers
Graham
I'm Graham.
Cheers
Graham
We are struggling to get a belt drive sub-forum implemented Graham so a Thorens specific one is probably out of the question
I started an essay here for TD160 setup and thought better of it. if you'd like me to prepare a setup guide from my experiences with hundreds of these things, I'd be happy to submit one for assessment for the library and comments from others..
I'm Graham.
Cheers for that offer. I,d love to read the stuff you have prepared on the TD160 optimisation
I have the SME 3009 II Imp too
Shame we can't have a Thorens group, it saves a lot of time searching
Thanks again
Graham
I'm Nobody.
You need the Analog dept web site for your Thorens requirement
I'm Mark.
Agreed, Thorens are generally easy to set up. Why a separate group? Most questions can be answered quickly. I reckon nearly everybody on AOS has had a TD something or other at some time.
I'm Mark.
Forgot to mention getting a better mat (Blue Horizon or summat) and a record clamp (Michell) will make big improvements too.
And if you really want to go mad then build or buy a power supply for it.
Mark
You don't need to spend stupid money on a Blue Horizon, Funk or Loricraft mat, since decent cork ones are available for twenty quid or less (I use several that are now available on fleabay for under a tenner).......
The suspension isn't that easy to get right without a little fore-knoeledge. There are cam-washers under each spring and if these are disturbed when levelling the sub-chassis, thay can take a while to get right if you've not done them before. Fortunately, Thorens put a couple of holes on the sub chassis and top plate that when viewed down through the "keyholes" in the top platter to help with centring and alignment. Cable dressing and clamping needs some thought too, and it's disappointing that all the new gorgeous looking replacement plinths out there don't have provision for this, unlike the originals.
I'm Graham.
Great feedback guys
In the process of priming the original Thorens plinth for painting
I have an off cut of granite here from my kitchen which I am thinking of getting cut for a replacement baseboard rather than a wooden one
I am about to order the cleaning / oil kit from Jo in Germany
I am struggling to justify a really expensive cartridge / stylus replacement so far
and wondering whether to stick wit the M75ED with new stylus or go for new cartridge. I also have an old Audio Technica cartridge and stylus from about 8 years ago but I have no way of identifying which one it is.
I am thinking about a cork mat too but still polishing the platter at the moment
Just reading around on here for best way to restore the cover too
Some of my 40 year old vinyl has sadly warped so I am wondering about a record clamp or weight to help wit this. Any thoughts on the max weight this should be on a Thorens TD10BII ?
Best way to polish the SME 3009 arm tube anyone ? It has some minor scuffs on it
What do you mean by cable dressing ?
Many thanks
Graham
