Have a Power supply for a Garrard 301,( different connections accepted)
can I use this to power my Alphason Sonata ?
I'm Trefor.
I'm Mark.
It's quite unlikely.
Mark
I'm Nobody.
I doubt it too.. G301 are induction motors
I'm Mark.
After a quick mooch on tinternet it seems to be not compatible at all.
The Sonata uses 2 Premotec motors as found in some Linn and Regas and others.
That means there are quite a lot of different power supplies available for the Alphason.
Mark
I'm Mark.
What connector do you have on the Alphason?
Mark
I'm Nobody.
Have a wurd with Gordon at Stamford Audio, the Mose: Hercules II' should work with the 'Sonata'..I recon you could shift the '301' supply straight away..
I'm Mark.
I'm Nobody.
Shows how much notice i take
Here's the supply anyway
http://www.stamfordaudio.co.uk/cgi-b...act=det&p=7158
I'm Trefor.
Wow what quick replies, everyone must be keeping warm up by their computer.
Regarding contact its a 5pin din. The deck has only a on/of button so I guess that this one is designed for a seperate P/s.
I't's really about just trying to get it up and running without too much cost.
Ps garrard P/s is a keeper
I'm Nobody.
Have you got a pic with the bottom off, you should be able to run the deck without the 'Atlas' supply..
