Originally Posted by
Haselsh1
I used -14db attenuators with my Croft pre/power just so that I could set the volume right. They worked extremely well and made up for the lack of finesse in the Croft pre. By the way I used them between the pre and power on the input to the power so that I effectively had to increase the volume control on the preamp. Great things, gave me much more control.
Iused Rothwell attenuators/Croft pre in the same position and found that although they did gove some more room on the volume control they killed the sound quite badly. Not sure how much attenuation the standard Rothwells supply, may be more than 14dB.
