Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 158
Thread: My First "Techie" - well part of it!
  1. #21
    I'm Ken.
    Default Update
    Filling the imperfections in the concrete with Chemical Metal.
    Weight of bare plinth gone up from 1.66Kg to 19.25Kg.
    Ordered 50mm dia Sorbothane feet (handle up to 40Kg accross set of four).
    Veneer on its way.
  2. #22
    I'm Andy.
    Quote Originally Posted by Qwin View Post
    Veneer on its way.
    Me so horny- Impulse H6 Horny
  3. #23
    nooooooo, don't veneer it!
  4. #24
    I'm Ken.
    I've decided to go all retro with this deck so the top and sides will be American Black Walnut veneer. This will be finished with Danish Oil.
    I am bored with paint, I finished my last two belt drive decks in Black paint, one in piano gloss the other in satin. They pick up dust really easy so I guess I am looking for easy maintenance, plus I will be using the same veneer on the concrete cabinets for my Tannoy Cheviots, when I get round to them, still not finished my battery powered MC phono stage yet.
  5. #25
    I'm Andy.
  6. #26
    I'm Ken.
    Default Update
    Applied the veneer to the sides.
    Painted the base and applied the Feet.
    Applied the veneer to the top, it took a lot of heat as the alloy drew all the heat away, used an iron set to Max, with a hot air paint stripping gun to help out.
    I had made templates for the cable entry and tonearm mounting holes, so I could find them when cutting through the veneer. Gave it a trim and a light sanding.
    I’m ready to start the cosmetic work on the motor cavity now. Had to leave this till the veneer was down, as a test on the piece of die casting I trimmed off, proved a lot of heat was needed and any paint I applied might blister, so left it till now.
  7. #27
    Man you are an artist - beautiful work - keep the updates coming!
  8. #28
    Alex_UK's Avatar
    Quote Originally Posted by costerdock View Post
    +1
    Alex
  9. #29
    Good stuff so far. I noticed you did the same intrinsic mod as myself where I filled all the screw holes in. I did this to strengthen the sub-plinth and try and reduce resonance. Good luck with this, looking cool.
    PRE
  10. #30
    I'm Andy.
    Ken- that looks stunning- can you do mine for me
