Results 1 to 9 of 9
Thread: Hi from Devon
    Default Hi from Devon
    My main listening system is PC based running into a Abrahamsen V6 DAC to HE-6 headphones via a Primare 100W dual mono amp
    In the near future I hope to upgrade the amp to a Class A ( maybe First watt ?) and get a balanced pre amp
    The dining room system was a budget challenge and ended up as an HK630 feeding Mission 760ise (for under £20)
    Musical tastes vary from Joss Stone, through Trance, Whitesnake,to Classical Organ
    MartinT Guest
    Hello David and welcome to AoS
    I've never heard of your DAC but the Primare kit is nice.
    Hi David,
    Welcome to AoS. Yes some more info on the DAC (links, etc) would be good
    Hi David,
    Marco
    the company http://www.abrahamsenaudio.no/ is run by the guy who used to run Electrocompaniet (and the V6 is similar to the ECD-1, though sounds better and was cheaper!)
    I believe they have stopped production of the A series to make way for new models
    Pic of the V6:
    Thanks for that, David.
    Yes, I recognise the Electrocompaniet 'house styling'! I've always rated their equipment - definitely one of my favourite manufacturers of solid-state equipment. I also like Primare and Densen kit - all the Danish stuff sounds great
    So how much is the V6?
    I'm Phil.
    nice one, spent a week in compton some years ago and thoroughly enjoyed it
    Eric Bibb
    MartinT Guest
    Yes, that looks very Electrocompaniet in style.
    I think I paid £260 new
    It has balanced connections (which are superb) but the USB input is not that good - I use an Audio-gd DI for that
    I'm ChrisB.
    Hi David, Welcome to AoS from me too.
    I just had a quick look at the Abrahamsen website and was interested to see that they're marketing what looks like an updated version of the original Electro power amp. It looks rather nice too.
