Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 81
Thread: Heybrook 'TT2'
    I'm Shane.
    You've got your work cut out with that one!
    No, I disagree. The major parts of the TT2 were very substantial and unstressed, so I can't really think of anything that's likely to have suffered that much other than cosmetically. If it's had a really heavy bash then I guess the sub-platter could wobble on top of the spindle, but that could be dealt with. The only thing I can think of that would be a real problem would be if any of the rubber spring mountings needed replacing. They were specially moulded for the TT2 and would be hard to replicate.
    The only parts that would be subject to wear would be the motor, belt and bearing. The motor could be replaced with a DC jobbie, a swift call to Heybrook will procure a belt (I bought one last year, so they're still around), and as I said above, in the unlikely event of the bearing needing replacing, any competent engineering shop could knock up a new one. I could let you know more details of the bearing construction if need be, although I don't have the original drawings. Should have kept them when I left...
    Hi Shane,
    You're right, of course - I simply meant in a cosmetic sense. It's so bashed and scratched looking that I couldn't ever have something like that in my system (I like my gear to look pristine) but I'm sure Andre is very capable of sorting it out!
    Me? That's a different matter entirely. I'm not exactly 'Mr D.I.Y', hence why I made my original comment!
    Quote Originally Posted by shane View Post
    Ok landed this morning.It's one of the first ones with the metal welded cross suspension frame.Unit number:'532'...I've had it running & the motors in perfect nick, very strong when you grab the pulley when running.I've had a new belt in a bag for about 8 years so that's no problem.The bearings in perfect nic, infact like new..although the original owner obviously has no respect for his gear he's kept the bearing over oiled if anything.The only thing i was worried about was damage to the name plate by the power switch but it's just a couple of white gloss paint specs that can easily removed, always made me wonder why people persist on keeping there equipment out while they decorating the house.
    Rubber mounts seem ok, i got them soaking in soapy water now, no cracks just a bit dirty, springs seem fine, i'll measure them against linn springs but i think the lins may be a lot stiffer than the Heybrooks..Sized & ordered all polished stainless steel bolts to replace the rust mild steel ones for a nice touch...
    Need a new armboard.This will be laminated with shiney black acrylic for a classy touch.That's it really not a massive job, couple week's hard at it should do the trick.Platter & lid will take the largest amount of time.These lids are hard perspex & take a lot of effort getting scratches out.
    Stay tooned folks.
    I'm Shane.
    Did you check the positions of the springs before you took them off? You have to juggle with their rotation to get an even bounce. Most TT2s left the factory with a red line drawn down each spring and a little triangular sticker stuck on the chassis next to each spring. If they're still there, then bob's your uncle. If not, then a bit of trial-and-error will be called for.
    There's no point in comparing the spring-lengths with Linn springs, they were completely different. The Linn's much heavier mazak platter means that their springs were much harder than ours. Incidentally we did try out a platter and sub-platter made from the same alloy as the Linn's but it killed the sound completely. Slow, dull and boring.
    If you need a new lid, they were bought in from Linn, as were the felt mats.
    Yeh no worries Shane all noted, the stickers are still there.Aye the hinges & hinge pockets are Linn aswell, later Ariston, Logics etc all used the same hinges.I think a clear lid would look better than the smoked one.Trouble being the Linn lids these days seem to be of shitty quality than older ones, i noticed this & the recess for the Linn badge looks smaller than the Heybrook lid badge.No worries about the springs they look fine, as you say the platters not as heavy as the linns so shouldn't have put too much stress on them over the years.
    I'm Ralph.
    Is this what you made the frame for then big boy?
    Ralph.
    Quote Originally Posted by CornishPasty View Post
    No Ralph but the idea did pass my mind..Things arn't going to plan with this Heybrook because of how it's constructed.My brains presently on fire at the moment...
    I'm Shane.
    Just out of interest, what are yoy trying to do with it?
    Hi Shane
    Needs re-veneering as it's un savable.I'm not a fan of veneer as it is, i think it cheap shite to be honest. I'm gonna replicate surround in solid hardwood.I'm a fussy bugger, qwality is very improtant to me.
    I'm Shane.
    Shouldn't be too hard. The veneered bit is just stuck round the outside to hide the innards and support the lid. It's the four layers of chipboard inside that do the work. Don't forget to put the arm-cable clamping block back in the right place.
Tags for this Thread
