After the recent crap weather the sun finally came out today, so after a hearty fry up with my wife at a local greasy spoon ( it was superb by the way Marco ) i donned a woolly hat and took out my old heap for a quick trip around the block to give her a run
Upon my return i discovered that i had a split water hose , i made up a new hose from a scrap bit i had lying around, fired it up again to check for leaks the thing then decided to get stuck in gear, pulling and pushing the gear stick whilst rocking it back and forwards had no affect so i then had to remove all the floor matting, take the gear stick out and peer down into the gearbox to see what was occurring, managed to get a screw driver down the hole and line everything back up, luckily it was only a selector out of line so nothing broken, a new gasket also had to be made as the old one fell to bits upon its disturbance, re-inserted the gear stick complete with cardboard box gasket and hay presto we had a full set of gears again a blast down to the local shops and all seems to be fine now.
Nothing like a old landy with no top on and a Rover V8 to listen to who needs a radio or a roof.
In the end i got about 10 mins of driving and spent the other 2 or 3 hours tinkering, the joys of owing a fine piece of British engineering, the grin factor makes it all worth it
Perhaps i'm posting this on the wrong forum but thought some of you might be interested i what i play with other than Hifi
By they way its a 1983 109 inch series 3 stage 1 v8 (factory Fitted), ex Water board
