Page 44 of 76 FirstFirst ... 34424344454654 ... LastLast
Results 431 to 440 of 756
Thread: DIY phonostage.
  1. #431
    I'm Simon.
    I've never used under 400.
    You can set the curve trace range on the pc 1-14ua is ideal.
  2. #432
    I'm Slav.
    What's the best/latest transistor choice for Calvins buffer, manuals states :
    Q3,Q6 - 2SA1381
    Q1,Q4 - PF5102
    Q2,Q5 - J107
    thanks
  3. #433
    I'm Simon.
    That's it. The j107 and pf5102 need to be matched though.
  4. #434
    I'm Slav.
    Thanks , where did you get 2SA1381 from , Mouser don't seem to stock these
  5. #435
    I'm Simon.
    They don't. KSA1381 is a replacement part, or any of these with adjustments to these caps.
    BD 140 (Suffix -16) ( C1,C2 = 180-220pF)
    MJE/MJD 350 ( C1,C2 = 100-47pF)
    2SB 649/A (Suffix C oder D)
    2SA 1930 ( C1,C2 = 180-220pF)
    MJE 253 ( C1,C2 = 47-22pF)
  6. #436
    I'm Slav.
    Thank you Simon
  7. #437
    I'm Slav.
    What's the best place to get matched pairs of 2SK170, please?
  8. #438
    I'm Simon.
    http://stores.ebay.co.uk/Himmels-Roh...p2047675.l2563
    There's a few others with legit parts but 99% 0n eBay are fake. This guys are legit and well matched, I've used him for years.
  9. #439
    I'm Simon.
    Get the BL grade
  10. #440
    I'm Slav.
    Get the BL grade
    Thanks , I will
