Page 35 of 76 FirstFirst ... 25333435363745 ... LastLast
Results 341 to 350 of 753
Thread: DIY phonostage.
  1. #341
    RothwellAudio Guest
    You are rather missing the point.
    Maybe I am. What is the point?
  2. #342
    I'm Jez.
    It all sounds a bit mad. BC327s are common transistors that cost 4 pence each when you buy 100 of them. These guys will select ones with Hfe of 400 and charge you £9.52 each for them. However, the usual design approach is to use negative feedback to eliminate component variations so the particular Hfe of any one transistor doesn't really matter.
    It has no negative feedback and is DC coupled...
  3. #343
    RothwellAudio Guest
    Quote Originally Posted by Arkless Electronics View Post
    I'm not sure I could even get anything useful out of a BC327 without negative feedback
    I certainly don't want to pay £952 for the 4(?) I want plus 96 I don't want.
  4. #344
    I'm Jez.
    They are a perfectly normal BJT and fairly quiet at the bias used. A lot are used in this design. To match properly you need to do it at the conditions seen in the circuit. Matching them with the Hfe setting on a multimeter will not do! Potentially, several matching jigs or one adjustable one will be needed. I can't be arsed to count them but there's probably something like 30 transistors per channel in this design and most need matching. You wouldn't need to match for example all the BC327 to each other, more a case of pnp and npn opposites to each other. To get enough matched pairs with close enough matching you may well need to buy say 500 to build one unit and it will take hours of work to do.... Even though I would agree that the price of the pre-matched ones above is well steep!
  5. #345
    RothwellAudio Guest
    I haven't seen a circuit diagram from this design but when I'm designing something I prefer not to rely on transistors having any specific performance. I thought that's what good design was all about.
  6. #346
    I'm Sandro.
    Well one thing is they will charge 550 even if they can not match them
    On semi sez that they can screen the PNP but not the NPN but advertise them as complementary Case for advertising standard ombudsman ?
    Other quoted that to get screened transistor the minimum Purchase Quantity would be 250000 units Maybe around £16000 (possibly much less )
    Group buy any one?
    I had the R2 built and believe me it is one of the best around
    Simon did ear it for about an hour or so and ended up building 23 of those
    One thing that I found was that Salas Simplistic had much more accurate staging and I am sure that this is not a Paradise related problem but due to my build whit poor transistor matching
    I have the DCA pro (best money ever spent) now and I am sure I can do much better than before but trust me when I tell you testing 5000 transistor will give you sore back
  7. #347
    I'm Sandro.
    Quite agree whit you I wish I could design circuits I am much better at hammering and welding
    That you have not seen the circuit is lets say not good just a few resistor values to change and use Toshibas complementary pairs may be the answer but this is way above what I can do
  8. #348
    I'm Jez.
    Yes it makes things vastly cheaper, easier and more reproducible to do things that way... but not always better
  9. #349
    Default DIY phonostage.
    I'd like to try one of these stages but it would need to be built for me or are there any demo ones available? I'm assuming not but I live in hope.
  10. #350
    I'd like to try one of these stages but it would need to be built for me or are there any demo ones available? I'm assuming not but I in hope.
    You need to buy one.
    PRE
