Page 25 of 76 FirstFirst ... 1523242526273575 ... LastLast
Results 241 to 250 of 753
Thread: DIY phonostage.
  1. #241
    I'm Simon.
    Just the shunts output devices to go in and the heatsinks to bolt on.
  2. #242
    I'm Simon.
    Last parts of my psu arrived today. Quad railed choke reg psu here we come.
  3. #243
    I'm Simon.
    Frankly it's about bloody time I built the first psu like this for someone else over 18 months ago, I'm well behind the times.
  4. #244
    I'm staring at a similar box of bits myself.
    I need to push on and sort out a rear panel for the PSU enclosure.
    My motivation isn't helped by the fact that I don't actually NEED a phono stage any more.
    Analogue: Technics SL1210 M5G, AN Arm One/II, Blue Angel Mantis MC
    Amps: Devialet 200
    Speakers: Usher Mini 2 Dancer DMD
    Cables: Supra, Mark Grant, Reference Fidelity
    DIY System Audiosector Gainclone, Salas DCB1, AudioSector MC Phono stage
  5. #245
    I'm Simon.
    You'll need it once you hear it.
  6. #246
    Si empty your inbox.
    PRE
  7. #247
    I'm Simon.
    Done
  8. #248
    I'm Thommy.
    I have a set of R2 boards + parts from the group buy a while ago, along with some hacker cap boards and 18v r-core transformers. I also have an enclosure now with holes drilled in the right places to hold the boards, so soldering iron time is fast approaching.
    Now as there has been a huge amount of fuss over this particular device, both in terms of it's performance and peculiarities, I am both excited and apprehensive about completing it.
    Actually, the problem I now face is information overload, or "can't see the wood for the trees" and am frightened about even starting it. Could some of you with experience maybe chime in and help if I post a new build thread?
    Speakers: Wilmslow Audio Prestige, ATC SCM11, B&W 602S02
    Cables: Missing Link Cryo Ref, handmade pure silver Litz braid, Van Damme Blue
    Amps: Hypex nCore400, DIY SET EL34/ECC83, DIY PP KT88 Monoblocks, Hypex UcD400 HG
    DACs: Quad Deck DDDAC, Single Deck DDDAC, Modified Chinese 9018, DIY Russian TDA1543 DAC
    Turntable: Technics SL1200 Modified, linear PSU, Paradise Phono Preamp
    Interconnects: Handmade silver Litz, Missing Link Alaqeia
    Preamps: DIY - buffers, LDR attenuators, stepped pots
    Mains: Balancing transformers, RF filters, handmade cables
  9. #249
    I'm Simon.
    Sorry Thommy i'd not seen your post. Any questions just ask.
    In the meantime, Here's upgrades for rexton's Paradise. 2sk170 on the shunt, organic polymer caps and toriodals for the psu. These caps are a bit of a bugger to retrofit, much easier on a naked board.
  10. #250
    Looks sexy!
    PRE
