Page 13 of 76 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 753
Thread: DIY phonostage.
  1. #121
    I'm inthescottishmafia.
    Thanks Simon, will do.
    Hunter S Thompson
  2. #122
    The only one disappointed will be your Mrs Andy when she finds you still in your music seat tomorrow morning.
    I've done about 6 hours so far!
    PRE
  3. #123
    I'm Simon.
    I've done exactly the he same since I got back... Agnes Obel, Atoms For Peace and all my Tom Waits.
  4. #124
    I stopped about 10pm with the MRS complaining of too much bass from JS Bach toccato and B minor!
    PRE
  5. #125
    A new group buy of the Paradise phono has just been announced on DIY Audio:
    http://www.diyaudio.com/forums/group...ml#post3811631
    Get it while you can.
    Thanks for the heads up Mark
    Alan
  6. #126
    You're a bad influence Simon!
    This might take a while.
    Analogue: Technics SL1210 M5G, AN Arm One/II, Blue Angel Mantis MC
    Amps: Devialet 200
    Speakers: Usher Mini 2 Dancer DMD
    Cables: Supra, Mark Grant, Reference Fidelity
    DIY System Audiosector Gainclone, Salas DCB1, AudioSector MC Phono stage
  7. #127
    LOL best of luck with the matching
    Mine is up and running now and sounding very nice, still early days yet though.
    phono 1 by 337alant, on Flickr
    phono 4 by 337alant, on Flickr
    phono 5 by 337alant, on Flickr
    phono 3 by 337alant, on Flickr
    Alan
  8. #128
    I'm Simon.
    ooh, DCA pro, nice purchase. I like the molex socket as well, that has to be quicker than clipping the leads.
    I've actually just built another one this week, R2 pcbs, numerical match on the input stage better than 1% everywhere else.
  9. #129
    With 2000 transistors to test (1K of each) the molex was essential.
    If I can't find a suitable matching set from that lot I may throw my hat at it.
    Amps: Devialet 200
  10. #130
    I just used a project bread board and clipped the leads on to some jumper wires easy and quick to just plug in the transistor
    http://www.ebay.co.uk/itm/400-points...item19d27245e6
    I printed off A4 sheets with squares numbered from 400 to 450 for 337 and 327 .
    after a frustrating time of testing and retesting in a room where the temp was not stable I found that 1-2 deg change in room temp moves the HFE up and down by up to 20 points so I ended up with a closed room with a stable temp of 22 degC and wore gloves.
    I went thousands of transistors and found that most of them where in the 300 to 399 range so a waist really
    Its a sole destroying job so best of luck
    Alan
